whrilpool washing machine AWM 5125
Home Forums Public Support Forums Help And Support Washing Machine Help Forum whrilpool washing machine AWM 5125
  • #49760
    menbed
    Have a problem with a whrilpool washing machine, I did sorry to post this question in wrong section,
    Machine will switch on showing red active led,the motorised programmer knob will motor around, but on any wash cycle the washer will not fill with either hot or cold water, and the same on a spin rinse cycle , but you can hear the pump running.
    Also the drum will only very intermittently run but slowly,but will not turn in the spin and rince cycle.
    the fault started by stopping longer than normal between cycles in a wash programme, but did finish the proramme, then it got worse
    any one any ideas
    thanks
    Tony Smith
    #302208
    don
    Re: whrilpool washing machine AWM 5125
    menbed wrote:Hi
    Tony Smith
    No probs, duplicate thread deleted 🙂
    Don
    #302209
    menbed
    Just to let you all know I have fixed the Whrilpool washer
    Fault turned out to be worn out motor brushes, not sure why the water never came in , may have been that the logic of the machine expects to see motor tacho before opening the water mag valves, or may be a red herring.
    As most of you repair folks may well know, this model is not that bad to work on, the motor is held on by one bolt which has a captive thread, and almost self adjusts the belt tension by the weight of the motor pulling down on the belt.
    there is no motor control board so the programmer is driving all the motor windings by relays, and no transformer to fail in the programmer, as its just mains ac into the bridge rectifier
    The local repair shop had the brushes in stock at £18:00 a set, albeit they were not a direct match the brush tapper was the opposite way, so you have to turn the brush in the plastic body by 180 degrees, and cut a bit out of the plastic body to let the brush connection tail out.
    Thanks fella’s and ladies
    Tony Smith
