Why can’t liquids/tablets and gels contain bleach?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Why can’t liquids/tablets and gels contain bleach?
  • #81792
    Ryannnn
    I don’t see it explained anywhere.
    You use bleach for the toilet which is in what form? Liquid?!
    So why can’t liquid detergents contain it?
    #417728
    Re: Why can’t liquids/tablets and gels contain bleach?
    Liquid detergents have a greater dispersal rate and are formulated for use in much lower temperatures than their powder equivalent.
    #417729
    And in bottles of liquid detergent the bleach would separate and sink to the bottom. Now even if you put ‘shake the bottle first’ on the side, could you trust the great British public to actually read the label in the first place. :rolls:
    #417730
    Ryannnn
    Martin wrote:Liquid detergents have a greater dispersal rate and are formulated for use in much lower temperatures than their powder equivalent.
    I have been told that they actually can’t contain bleach though.
    iadom wrote:And in bottles of liquid detergent the bleach would separate and sink to the bottom. Now even if you put ‘shake the bottle first’ on the side, could you trust the great British public to actually read the label in the first place. :rolls:
    But you don’t have to shake bottles of bleach?
    I don’t understand.
    #417731
    DOH, because there is only bleach in the bloody bottle. :rolls:
    #417732
    Bleach is heavy.
    In the same way that oil floats on water, bleach sinks.
    In a bottle of bleach, that doesn’t matter. Bleach in another liquid, it does.
    So far as I know it is incompatible with the dissolvable coatings used on tabs so, can’t be used there either.
    Ryannnn
    kwatt wrote:Bleach is heavy.
    Yeah i guess that makes sense about the coatings because it would probably dissolve them before they could even be used.
    But i would have thought in the bottles of liquids or gels that they could just tell the consumer to give it a good shake before pouring it out, a bit like a vinaigrette.
    #417734
    Ryannnn wrote:But i would have thought in the bottles of liquids or gels that they could just tell the consumer to give it a good shake before pouring it out, a bit like a vinaigrette.
    Been tried, failed.
    As Jim said, people generally don’t read instructions.
    Ryannnn
    kwatt wrote:
    Been tried, failed.
    Alright but assume they did do it, in this case could liquids become just as viable as powders in terms of quality and mould prevention?
    #417736
    Not enough data to answer confidently.
