Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Why do some oven elements last longer than others
- This topic has 13 replies, 9 voices, and was last updated 14 years, 7 months ago by
garn.
September 8, 2011 at 5:30 pm #64946
garn
Participanthi i installed a element on neff oven 11 months ago and It looks like It has Failed .
❓ why is it that some of these oven elements don’t last very long
Is down to genuine part or Paten part :con: :help:Garn
September 8, 2011 at 6:28 pm #358583admin
KeymasterRe: Why do some oven elements last longer than others
Ive found that a lot of the clamps that are on them are crimped too tight which then does not allow the element to expand and contract full but restricts the movement.. Yes they look all nice and neat but hot metal has to be given enough room to move. I have removed several of the clamps that have been too tight and have pressed into the outer sheaf.
Bryan
September 8, 2011 at 8:43 pm #358584gandh1
ParticipantRe: Why do some oven elements last longer than others
its a neff/bosch. door hinges on these are like soft cheese if anyone puts the slightest extra weight when open. the gap formed then doesnt allow the oven to heat properly and overworks the element.
then theres the oven cleaners using their spray cleaner…
then theres price vs quality. even decent element mfctrs are getting poorer quality, and the cheap cheap is hit and miss… and tying in with that is bryans overclamped brackets 🙂
September 9, 2011 at 7:40 am #358585keithwilliams
i find that elements are generally o.k. wether pattern or genuine. however there is one exception and that is the bosch/neff ones. and especially the “horse shoe” bosch.
i give a 12 months warranty and bosch/neff are the only ones that i have doubt as to if they’ll last it out.September 9, 2011 at 7:45 am #358586Martin
Guys, take a read of THIS THREAD 💡
September 9, 2011 at 8:17 am #358587garn
last year i done one where the customer supplied there own.
basally I was calculating the job in her kitchen and instantly she came up with a price she had on esapares on-line in front of me.
as you can imagine she had blown my quote out of the roof.
so i agreed to supply Labour only. six months later it had gone again .
i thought thanks, its not my responsibly you supplied the part
espares did supply another free and i had double labour 🙂 .September 9, 2011 at 8:45 am #358588electrofix
ModeratorRe: Why do some oven elements last longer than others
garn wrote:hi i installed a element on neff oven 11 months ago and It looks like It has Failed .
had more problems with the neff horse shoe element than any other. used ELE2052 but these used you blow bottom right hand corner seemed to me they had bent elements too close.
Then tried ele2052ego only to watch it go bang while i was watching it
So its Gen from now onDave
September 9, 2011 at 2:19 pm #358589Martin
I’ve had little success with genuine or pattern half moon (a.k.a. horseshoe) Neff/Bosch elements. Both of which are rated 1700 watts at 240volts, both look identical in every way and both fail short term equally in my experience. So much so that I stick to fitting the non-gen Qualtex ones. In the past I have fitted the ELE2052 and recently have tried the ELE2052EGO version. The latter so far, touch wood, has been OK with no recalls. But I won’t hold out any greater hope nevertheless.
In the light of constant oven element failure statistics I have amended the parts fitted guarantee I give. Before I always gave a 12 month warranty but now only stress a guarantee period of just 90 days on ALL elements and lamp bulbs.
When you closely observe the uneven hotspots of fan oven elements and especially the half moon variety (pattern of gen) as they run up to temperature, it’s easy to figure at some point soon it’s gonna blow in that area. 90 days is a long enough period for any manufacturing defects to manifest themselves. So my customers are happy with that reassurance overall. If they ain’t they can go some place else and get it sorted. 👿
September 9, 2011 at 5:46 pm #358590washtronics
i have had loads of bosch ele2052 qualtex element blowing within 3 months of fitting, they always blow in the same place near to fixing bracket, also had other bosch/neff ele2042 and ele2044 not last long
September 9, 2011 at 9:00 pm #358591admin
KeymasterWhy do some oven elements last longer than others
“” always blowing next to the clamp fixing””
As I have said the clamps are fitted to tight. I have first hand experience and have watched the elements been made to which is why when I bulk order mine direct I request NO fixing points fitted but supplied separately.out of over 3000 elements I have only had less than 100 failures in 5 years.
Bryan
September 9, 2011 at 9:21 pm #358592gandh1
to be fair to connect, i can count on one hand how many recalls we get for their 2300w bosch ring element, and we tend to do 2-3 a week… been using egoqtx ones too as theyre only few quid more, £70 for gen bosch is excessive when they dont seem to last much longer (on the whole) compared to connect patterns
September 9, 2011 at 9:22 pm #358593gandh1
also worth noting electrupart zanussi2500w are the same as whats in the zanussi packet for an extra £4 😉
September 11, 2011 at 8:32 pm #358594nomadPaul
Nearly all the failures I’ve seen…..and remembering 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} are gen BSH elements……have occurred on the bottom right corner .
Personally , I think its just a poor design….and so obviously do BSH as the new style double undercounter ovens have changed to a smaller ‘circular’ element .October 27, 2011 at 10:42 pm #358595walnut
Waisted 2 1/2 hrs today on these crap horse shoe elements.
I have fitted 2 EGO versions only to see a firework display as soon as I pick up my toolbox.
3 elements to fix one cooker and you can be sure the customer will be on the phone before the 6 months guarantee is up.
The frustrating part is that I know exactly why they are blowing, too many Watts per inch.
Over engineered German Bullshit. -
