WI 101
  • #39293
    machineman
    S/N 408257568
    need a new drum assy for this ,does anyone have the part Nos connections are cr-p
    thanks m
    #261949
    smartin
    Re: WI 101
    c00113810 hope this helps
    smartin
    #261950
    helo_75
    theres 3 listed for that machine
    2 are 46l drums, 1 is a 40l drum
    u also need to measure the shaft size, cos theres different sizes
    15mm / 17mm/ 20 mm
    #261951
    helo_75
    Re: WI 101
    smartin wrote:c00113810 hope this helps
    smartin
    which is a 46l tub, with a 17mm shaft
    unless you order a pulley as well, ull be taking a chance on it being the wrong size
    #261952
    smartin
    Re: WI 101
    oops missed that i shouldve used servicenet
    #261953
    helo_75 wrote:1 is a 4l drum
    That’s a really tiny drum…… :rotfl:
    :p45:
