wia 101uk
  • #29787
    robbo1973
    this machine will not reset . when you put the selector vertical which is off on these machines the door locked light continues to flash if you start a programme you cannot reset is this board.are there any fault codes about for these as i am having bother with a wia121uk as well. this machine has got the board at the top not the normal one at the bottom.does this machine need the hardware key i have read about ❓ .
    thanx chris.
    #224727
    johnnyj
    Re: wia 101uk
    New board req,d had a few doing the same only way to cure.
    #224728
    robbo1973
    Re: wia 101uk
    thought so cheers. any idea on fault codes on these ❓
