Have an issue with this washer/dryer. Door locks starts to fill then drains and the second neon light in the row of four starts flashing and door light is flashing rapidly. Think the error is a low level on the pressure switch error?? Can anyone confirm and explain?
this is a washer dryer. if it is the same board as used in the hotpoint washer dryers, the one mounted at the rear of the machine, then this is a known pcb problem
suggest you send pcb to emw for testing / repair
