Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › widl126uk light 2 / F04
- This topic has 6 replies, 4 voices, and was last updated 15 years, 8 months ago by
gandh1.
August 6, 2010 at 3:54 pm #56351
gandh1
Participant410203278 / 80305380000
pumps and drains continuously, when prog cancelled:
light 2 flashes. dryer fan starts whirring
with solenoids disconnected it loses teh flashing,
with 3x cold sols connected it will do a spin and drying cycle fine, however rinse or cold wash prog will do the light 2 flashing again.
before i order solenoids (wont be in till tues) tenants/landlords after fast answer but tight so if i say its teh board straight off then chances are ill miss out on a replacement purchase.
oh and no burnouts / dryjoints on the main module…
also took and tried a new p/switch as it was F04 on here before i went out, but same symptoms
August 6, 2010 at 4:06 pm #327009electrofix
ModeratorRe: widl126uk light 2 / F04
had this fault a few times on the hotpoint wd
its always the board send to emw
August 6, 2010 at 4:40 pm #327010gandh1
ParticipantRe: widl126uk light 2 / F04
if it is corrupt tho, would the ps cause the corruption? theres no point in sending it off to find out the board is fixable but it needs £120 of other kit too… :s
August 6, 2010 at 5:06 pm #327011Martin
gandh1 you have to take into account that it’s a widl you are on about…AND just like piddle, diddle, tiddle and even…..pig in the middle. Get the board looked at by EMW by all manner of means, why not? If it were me TBH…time to cut and run my friend…even if you sort it sure as eggs are eggs your ruddy phone will ring tomorrow with another widl cum diddle problem…. 😈 😉 8) 😀
August 9, 2010 at 10:04 pm #327012gandh1
elder couple. used twice a week, feel 4 years is a bit of a short life.
willing to spend up to £150 so have ordered hot feed solenoid (£6) and just whipped off a triple sol from teh display wdl520, so armed with these ill give it a shot tomorrow. fingers crossed.
emw seem 50/50 that it might fix it as the widl boards they normally fix where machines will constantly fill/drain usually dont show a clear error code being displayed. hmmm – interesting
can only try so will keep you all informed of progress 🙂
August 24, 2010 at 2:00 am #327013gandh1
main board dry joint and didnt want to try a repair “it didnt seem to wash too well anyway”
ps connects solenoids will not fit for the widl126 – right type of terminals, just wrong configuration of teeth to fit
August 24, 2010 at 5:08 pm #327014leavemetogetonwithit
gandh1 wrote:right type of terminals, just wrong configuration of teeth to fit
Yeah, I get the odd customer now and again that doesn’t smile.
Mike. -
