widxl126 washer/dryer
  • #59086
    deltra
    hi, machine sets off ok, fills, tumbles etc, doorlock lights,then after a while the door lock light goes out(programme light stays on,machine stops. then after a few secs it jumps back into life, door lock lights up again 😯 carries on working for a while and it starts to mess up again.. no fault code is produced. changed door lock, motor brushes,tested heater etc,everything tests ok,checked for broken wires. poss module fault ❓ any ideas much appreciated 😀
    #336756
    bazza500
    Re: widxl126 washer/dryer
    I have one doing exactly the same. Sent the module to EMW and it came back “no fault found”.
    If you find out what’s causing this let me know 😕
    #336757
    bazza500
    Just been reliably informed that the dryer thermistor causes this fault. Will try that later and let you know.
    #336758
    deltra
    cheers 8)
    #336759
    deltra
    tried dryer therm, still faulty :rolls: now been told possibly motor ❗ ❗
    #336760
    bazza500
    HA!! I just tried the dryer thermistor as well and it’s still faulty. I’ve tried it with the motor disconnected and it still pulses the pump.
    #336761
    I seem to remember something like this happening to a WIXL127 or some such number I worked on. It was the on/off or the start tactile switch that was worn out. Took one from an unused option button and all was OK. Think I may have also had to put in a link or two to get round the “hole” created where the option button had been. (I should emphasise that my memory of the whole affair is quite clouded now.) Intermittent fault of course, so not always found by EMW as they wouldn’t necessarily be fully informed of the nature of the fault.
    Mike.
    #336762
    Pigpen4
    I’ve just been to one with lights 1, 2 and 4 and dryer thermistor is open circuit.
    Looks the same as a water element thermistor, but is it the same part number, please?
