WIL 103 machine filling and emptying at the same time. have changed board, and now light 1 flashes saying fault code is heater relay,which i thought was the original problem,hence changed board anyone got any ideas.
WD 440 wash side works but faults on dryer side, fault code F13,dryer ntc or fan. ntc tested ok fan works ok replaced element which was open circuit, still same fault code. have now changed board and guess what same fault code reported initialy,went back to check set dryer away worked ok when i was present ,customer said he would try another load so went away and and some time later got call saying it hadnt worked properly and seems to go all through the drying cycle,but clothes are still wet so now presume thermal cut out has blown,will be going back monday.
having a bad end to what seemed to be a good week any thoughts much appreciated ,Darren
