Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › wil163 doin my head in!!!
- This topic has 9 replies, 5 voices, and was last updated 18 years, 10 months ago by
helo_75.
May 20, 2007 at 8:21 pm #27489
helo_75
Participantok
got a nightmare machine
went to look at it (wil163uk)
machine filled, no fault code, went to wash, motor struggled, wouldnt even spin
great put on a new motor, put on spin, spun fine
rear panel back on, pushed it back, quick try on wash…. wont wash, motor hums, but wont turn
fit new eprom and board, exactly same
checked all wires to motor, harness is fine
i spent 2 hours on that smeggin machine, and im none the wiser
any one any ideas?
May 20, 2007 at 8:42 pm #214315iadom
ModeratorRe: wil163 doin my head in!!!
Only one, and it involves Goatboys favourite medieval implement. 😉
May 20, 2007 at 8:48 pm #214316Penguin45
ParticipantRe: wil163 doin my head in!!!
Earth fault on heater? Only other component with worthwhile power consumption.
May 20, 2007 at 10:27 pm #214317helo_75
Participanthmm, did megger the machine, but that wont necessarily show a problem with the heater
ill give it a whirl when i go back
medieval implement?
May 20, 2007 at 10:35 pm #214318Penguin45
Trebuchet………. 😀 😀
May 20, 2007 at 10:40 pm #214319helo_75
:rolls:
layman terms please 😳
May 20, 2007 at 10:42 pm #214320macmini
I guess this is an under warranty job?
The cost of the parts easily out weigh the value of the machine!
You work for Comet don’t you? What is the exact criteria for the machine to be SED’d?
May 20, 2007 at 10:48 pm #214321helo_75
Participantlol… sed?
its an imco policy… tight gits they are
but the pencil pushers deem it repairable as long as cost per job stays low (average over 50 jobs)
id chuck it in the bin, trust me, but theyll throw hundreds at it, u watch!
May 20, 2007 at 10:49 pm #214322Penguin45
:snigger:
:p45:
May 21, 2007 at 9:46 pm #214323roly16
Before you employ the trebuchet it’s worth checking that the wires to the heater aren’t partially broken off at the terminals inside the insulators where you can’t see them. See my post on the model W133SUK; different symptoms but you never know……. :rolls: .
A trebuchet is a medieval siege engine, a weapon employed either to smash masonry walls or to throw projectiles over them. … 😀
