Will a VT9 thermostat adequately replace a K57 P2018? Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Will a VT9 thermostat adequately replace a K57 P2018? This topic has 4 replies, 3 voices, and was last updated 12 years, 2 months ago by PeterBl. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts January 31, 2014 at 7:20 pm #79307 PeterBlParticipant K57 P2018 appears to be discontinued and I haven’t found specifications for it on the net. Will a VT9 do the job? January 31, 2014 at 8:13 pm #408764 adminKeymaster Re: Will a VT9 thermostat adequately replace a K57 P2018? Hi What’s it for ?? Bryan January 31, 2014 at 9:47 pm #408765 PeterBlParticipant Re: Will a VT9 thermostat adequately replace a K57 P2018? For the fridge section of an old Electrolux ER3201B fridge/freezer with auto defrost. I am guessing now on more research that given this is a wet wall fridge freezer then rather than the VT9 I need a Ranco VXO? February 1, 2014 at 8:46 am #408766 ELDAR59Participant Re: Will a VT9 thermostat adequately replace a K57 P2018? Hello, the vt9 stat should be suitable for a wet wall evaporator. The vxo stat turns off at a higher temperature. I’d go with the vt9, February 1, 2014 at 1:46 pm #408767 PeterBlParticipant Re: Will a VT9 thermostat adequately replace a K57 P2018? Thanks, I’ll try the VT9 then. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
