Re: will my English fridge work in Australia ?
hi Lucy,
check the rating plate for its climate class,
Climate class.
Every fridge has a ‘climate class’, which tells you the range of room temperatures with which it can cope. The two you’re most likely to come across in the UK are N class and SN class.
Both work effectively in room temperatures up to 32°C.
N models shouldn’t be used in rooms that become colder than 16°C. SN models shouldn’t be used at room temperatures below 10°C.
Other classes that you might come across are ST and T. ST models work best at between 18°C and 38°C, and T models between 18°C and 43°C.
Bob.
