Wine Cooler Repair
  • #89021
    RoboProd
    Cooler switches on no issues, control panel lights up and compressor runs. After a while the compressor becomes hot although the cooler doesn’t chill. There are no fans around the compressor so can rule that out as an issue.
    I checked the resistance across the compressor, PTC relay and overload relay and all seemed to check out – overload relay had 2 ohms of resistance so bought a replacement and PTC relay just to be safe.
    Any suggestions?
    #440079
    Re: Wine Cooler Repair
    if the compressor is running then its either a gas problem ( lack of or none ie leaked out) or the compressor is gone
    either way its a specialist job and unless its just gas and then maybe its worth it but the compressor is not
    i could not do this job so as a non professional you will not be able to
    RoboProd
    How much to regas roughly?
    #440081
    Compressor swap, somewhere North of about £120 I’d think.
    Regassing it, depends who does it where but think on about £80 plus.
    RoboProd
    Unlikely to be what I suggested above?
    #440083
    Nope. Dave is correct I’d think by the sound of it.
    It’s probably a dodgy pot as, it’ll probably be a Chinese thing, with a Chinese pot in it so, the math says…
    ELDAR59
    There’s a lot of these about right now with leaking evaporators.
    That’s probably the root cause of the problem.
    #440085
    RoboProd
    It’s a few years old and has been transported on its side a few times – looks like a trip to the dump is needed.
