Wiring diagram
  • #103562
    kaibart
    Hi all I’m looking for a wiring diagram for a caple oven model number C2233 vestel made
    S/n 00689130006718770191
    no power to fan motor or ring element, was rushing on Sunday and thought it was switch, still not working, as its neutral switching need wiring diagram tia Kai
    #493707
    My access doesn’t have that one listed, ASWO might have it (I’m banned apparently) but Dave may be able to check.
    kaibart
    No aswo hasn’t got it that’s why I’ve posted here thanks k
    #493709
    yes as you say Aswo has no diagram
    some of them have strip down manual with pictures
    have you eliminated the switch as its often the rear contact that cuts power to everything on a lot of ovens
    kaibart
    Ive changed the switch and checked the contacts, I’ve bypassed the stat on the back of oven that neutral feed comes from and I have voltage live and neutral to switch on thing that gets energised is cooling fan and I’ve bypassed thermostat, it’s a basic oven timer stat and selector switch but it’s switched on the neutral side only thing I can’t check is the clock
    #493711
    kaibart wrote:only thing I can’t check is the clock
    you can ,l look for the relay contacts on the clock and bridge then or measure across it as it should be 0v when energised and time set
    kaibart
    Can’t it’s just live and neutral into the clock and a single wire out to the switch
    #493713
    well Aswo list clock below for above model
    you can see relay on the left
    join wires together or check they are same voltage when live and set
    kaibart
    Thanks Dave
    #493715
    kaibart
    Well called back to this one today as I had a timer but was 5 button but 1 relay got the internal light to work and then the fan motor to work on the grill setting when I looked at the contacts on switch wires where in a different position on the new switch all up and running thanks both for your help kai
