Has anyone one of these? I am encountering strange problems and need to double check the oven selector switch, the fact they are so straight forward just makes it more frustrating!
bear in mind that these products have a thermal fuse on the wiring you can hardly tell but if you check in the back of the appliance you will see that the power supply wiring to the element is a bit thicker and this is where the thermal fuse is.
I am guessing that will be your problem as it throws everybody till they are told of it.
