wiring diagram for Sole motor
Home Forums Public Support Forums Help And Support Washing Machine Help Forum wiring diagram for Sole motor
  • #7881
    Got an old band-saw with deffect motor.
    Have picked out a 1-fased solemotor from a washing maskine.
    Too many wirings from the motor. (7)
    NEED BADLY A WIRING DIAGRAM for this motor for use on 240v~ 1-fase.
    Picture of motor :
    http://home.online.no/~trotech/bandsaw/
    #125617
    Dave_Conway
    Re: wiring diagram for Sole motor
    This isn’t going to be easy I’m afraid, the motor, as you are probably aware is multi-pole and uni-directional with various speeds.
    Any idea of the model of Zanussi it came from as that’s about the only chance we’ll have of checking this ?
    Even then, it may prove to be a trial and error thing. Don’t forget you’ll need the capacitor for it as well.
    #125618
    Trotech wrote:Got an old band-saw with deffect motor.
    Picture of motor :
    I admit that it would be difficult to solve this task.
    My work is on Radio Tv service, so I’m not so comfortable with those motors.
    Anyway. A label on the motor say:(Hardly readebly)
    5 SOLE Maid in ITALY
    7 Type 20571.277 Cl.F
    2 230-240v~ 50Hz
    7 A W RPM uF VL
    3 3.4 170 2850 16 450
    7 1.6 60 320 16 300
    0 12403661/1 *4.35.M*
    The most i understand, but not the left vertical numbers (5727370) and What is VL (450 / 300) ?, and the last line.
    It is possible that this motor come from a Sanussi, but i did not look after when i picked out the Motor and the Condensator. I had about 20 machines to select among, and mostly of them looks to have the same motor.
    Since my hobby is woodworking, I’m making some toys for my granchildren. A fully working bandsaw with new motor would be the top of the hill for me.
    #125619
    Dave_Conway
    May I make a suggestion please 😉
    Go to your local recyling point and grab an old twin tub washing machine.
    The motors are far simpler, single pole etc.
    On the whole they will have a V belt pulley already fitted as well.
    #125620
    dpm
    Looks suspiciously like the motor in the old 918. I’d tend to agree with Dave tho- do the speeds even suit you? Most induction motors are 1440rpm so unless you alter pulley sizing etc, 320 or 2850 would cause problems…
    #125621
    It seems to be a good idea to find a another motor not so complicated, so I went back to my local recycling place and found a twin tub washing machine. After a lot of struggeling to get out the motor, I discovered that the rotor shaft didn´t fit on wheel on the saw. 😥
    At the time now it is snowing heavy, so I have to wait until tomorrow and start over again.
    Now i´m scanning the net for finding some chematic for how to connect the capacitor. Somethin tells me that the connections are easy. But I have to know for certain. I cannot give up now, so i´ll be back.
    #125622
    Finally I made it!!
    With the Sole motor.
    Now i have 2 speeds and the band saw is working fine.
    After experimenting with 7 colored wires and the condensator I´ve got the hang of it.
    Well. The speed at 2850 is someway high, and i left the room when the saw started, but it didn´t come after me, so I went back and tested it.
    All i can say is that everything isok now. 😆
    But. Thanks for trying to support me. Forums like this worth gold for guys like me.
    #125623
    John47
    Any change you could send me the details. I have a similar project for using a sole motor. My email address is johnhfranco~hotmail.com.
    #125624
    Alan 52
    What were the 7 colored wires and what weirs did you connect to them.
    #125625
    Alan 52 wrote:What were the 7 colored wires and what weirs did you connect to them.
    That post was 12 YEARS ago, he’s bound to remember I would think. 😉
