I need a motor/door wiring harness for the above model.
I have 1603396 which has a red coded motor plug, but the original plug is black with different keyways. Is there a part number for the black coded plug/loom?
Yes the plugs are white, but one has a streak of red “paint”, the other black, as I said the keyways are different. Obviously for a reason. To make this loom fit I would have to start cutting away plastic keys. Wouldnt have thought I would have to do that.
Did a WMA today and had a quick look at the wiring harness. Just a thought, you are trying to put the motor plug in the right way round, thats to say with the wiring coming out upwards, facing towards the outer drum and not down towards the floor?
