during maintenance 2 wires came disconnected from timer to pressure switch. Bendix model wcd1025 PFI197030427. timer p/n116103032 disconnected orange wire has105.c printed on it tan disconnected wire has E2F9. The pressure switch no part number has 4 unused pins #11#12#21#32. Need help with which pins to use for the orange and tan wire. Thanks James
kwatt thanks for the reply. I have rechecked the data plat and the number are correct. Model # WDC1025. PFI 197030427. The machine is old 1997 vintage info has been hard to find. That why I turned to this forum. I have resurched it a little further and found a part number for the pressure switch #116102798 and that an Equator EZ3600CEE machine has the timer #116103032 and pressure switch 116102798 installed a long with Splendide Combomatic 2000 .May be wiring diagram for these machines will give me the pin info I need. If I can find out what the orange and tan wire control I think I would be able with an ohm meter find which pin I need to use Thanks James
Unless someone happens to have an old paper copy, which I doubt, it’d likely be on an old microfiche so impossible to copy or print pretty much.
It is not listed on Electrolux’s UK portal at all so there’s no information available there whatsoever. Given the age of it, they probably didn’t bother to load it up there.
