Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Wiring issue?! Please help!
- This topic has 26 replies, 3 voices, and was last updated 5 years, 11 months ago by
Mattypompy99.
April 24, 2020 at 6:36 pm #468211
Mattypompy99
ParticipantBtw the new oven needs a minimum “3mm contact opening circuit breaker, rated 32a and a delayed functioning type must be installed inside supply circuit”
April 24, 2020 at 6:53 pm #468212Mattypompy99
Participanthttps://drive.google.com/file/d/1eSsLftxved_YkbPkGI-yfDYrABo03RtI/view?usp=drivesdk
Old oven connections
https://drive.google.com/file/d/1gZfT9OtnRjP5lO_eYUw76aTTldxwF-7n/view?usp=drivesdkMy speculative wiring diagram.
April 24, 2020 at 8:34 pm #468213electrofix
Moderatorthat makes more sense
all they have done is go in and out of the ovenso wire goes from switch to oven and oven to hob
chances are with the oven you have the terminal block will not be big enough to take 2 6mm cables so you will need to add a 30a 3 terminal joint box and you will need a short peice of cable to go from the box to the oven
April 24, 2020 at 8:50 pm #468214Mattypompy99
Participantelectrofix wrote:that makes more sense
Do you think that was a dangerous circuit configuration? The old oven element died, wondering if it was overloaded when hob and oven on together.
When you say terminal block do you mean the connection unit white box junction back plate thing? You’re saying I may need another one?
Can’t I just use a double appliance one? Like this.
There’s spare cable on the old oven. Thanks Dave, good man.April 24, 2020 at 8:53 pm #468215electrofix
Moderatordifference between new and old install. new one uses a joint box
April 24, 2020 at 9:05 pm #468216Mattypompy99
Participantelectrofix wrote:difference between new and old install. new one uses a joint box
Cool diagram cheers!
So basically one feed in two out platejunction boxconnection unit.Ta
April 25, 2020 at 12:40 am #468217Mattypompy99
Is a 30 amp junction box ok if cooker requires 32a?
Is this ok Dave?April 25, 2020 at 8:39 am #468218electrofix
Moderatorthe 32a rating really only relates to the size of the terminals as the cables are being squashed together anyway. so it will be fine
plus as with most appliances the current rating is max. Unless you have 10 people round for dinner its unlikley you will draw anywhere near this current. If your only using the oven it only takes 12A
April 25, 2020 at 2:35 pm #468219Mattypompy99
Participantelectrofix wrote:the 32a rating really only relates to the size of the terminals as the cables are being squashed together anyway. so it will be fine
Much appreciated, once again Dave. Wish I could buy you a for beer!
April 25, 2020 at 5:00 pm #468220electrofix
Moderatorjust want to out for a beer myself but we are all stuck in. Can’t wait for life to get some normality, but cant see that happening this summer some how
hope you sort it
April 26, 2020 at 12:29 am #468221Mattypompy99
Participantelectrofix wrote:just want to out for a beer myself but we are all stuck in. Can’t wait for life to get some normality, but cant see that happening this summer some how
hope you sort it
Yeah. I know what you mean. I have no outside space and live on a main road! On the upside I have a harbour side 2 min cycle away, so am better off than a lot. It’s peaceful sauntering down there on the scrubland. Think it will be late summer before any semblance of normality, that’s exlcuding pubs!
All the best. Matt
April 27, 2020 at 8:36 pm #468222Mattypompy99
hope you sort it
All sorted, cheers bud!
