wirlpool f/f Do the flashing red lights mean anything?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum wirlpool f/f Do the flashing red lights mean anything?
  • #23082
    royboy
    Whirlpool f/f s20brww20
    The ice machine packed up then got the chattering relay, spirting water and eventually the compressor went as well.
    So i changed the caps on the rear control board which has fixed
    everything except the ice maker.
    The red light on the infra red flashes in pulses of 2-0-2-0- etc does this mean
    anything ?
    Any other info on this problem would be a great help
    Thanks in advance.
    #196951
    DentedPorsche
    Re: wirlpool f/f Do the flashing red lights mean anything?
    It’s not detecting any fault.
    As your ice maker isn’t working it’s more than likely the rear board is faulty.
    Due to the cost and the possibility of requiring both boards it may be prudent to get an engineer in for this.
    DP
    #196952
    royboy
    So this is normal?
    #196953
    DentedPorsche
    Yes. If you hold the infra red flap closed the light should be on solid.
    With the beam broken (flap open) it flashes twice, pauses and repeats.
    This shows it’s working ok, i.e. not detecting a fault.
    #196954
    royboy
    On mine the light flashes whether the beam is broken or not does this narrow the problem down ie problem with the sender or reciever
    sorry for the late reply
    #196955
    DentedPorsche
    Sorry, it would be pure guesswork to give an answer on that.
    As parts are expensive for these machines I’d suggest getting an engineer in to diagnose. Would certainly be cheaper than guessing and throwing parts at it.
    DP
    #196956
    royboy
    Tried bypassing the sensor by bridging the infra red sensor but still dont get the solid red led, are you sure that the led should stay solid when receiving the signal in normal operation. Thanks for your patience.
