I have an Indesit/Hotpoint wixl143 for about 9 yrs, that has suddenly stopped working. I.e. It won’t switch on at all. I have checked the fuse and the wall socket and they are ok.
Considering the length of time it has been in use I suspect that the on/off switch has simply failed, the reason I suspect this is that just before it failed to switch on permanently it wouldn’t switch on, until I switched it off the wall opened the door, closed it and switched it on from the wall again, after that last wash, it simply refused to switch on after that.
Has anyone had a similar experience where the wixl143 simply refuses to switch on (no lights)?
What seems to be the usual cause?
The pcb or the on/off switch?
Does anyone know where I can get hold of an on/off switch for the wixl143?
