WJD1667W ZAN JET
  • #20146
    jenson
    Hi i have a fault with a zanussi wjd1667w auto when switched on it starts filling before you select a prog i have limited info on test procedure but cannot get machine to select any progs or get it in to test mode i suspect power card fault. have checked motor /pump heater for low readings but all test ok
    jenson
    #186022
    cab
    Re: WJD1667W ZAN JET
    hi, do you know how to access the diagnostic program, sounds like its stuck in a prog, are there 3 lines in the display when its turned on, if not press the pause button then the skip button to advance to the end.
    cab
