Had two of these to look at today both not heating on dry checked reset stat and they had tripped could not finded any reason why, checked air flow ok no blockage ect anyone help
yes i did ask if stopped before prog end no i didnt check fan area as the air flow seemed ok, so blocked vanes would cause fault and i didnt know that the corrugated hose was prone to blockage thanks for info
Haha. Had lid off watched condenser get water shoved high up it with drum half full of water on spin. The lint that came out then blocked the drain pump. 16 mins it carries on for. I stood back in the end
