Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › WM-1465FHD
- This topic has 5 replies, 2 voices, and was last updated 20 years, 8 months ago by
Ellis.
July 22, 2005 at 8:01 pm #10846
Ellis
ParticipantHi
I have an LG WM-1465FHD and the washer has now stopped mid cycle and full of water with an error: OE
I have emptied the filter from the bottom left drawer? Do you know what this code means?!
PLEASE HELP!July 22, 2005 at 8:02 pm #142929Ellis
ParticipantRe: WM-1465FHD
The OE is flashing and Im not sure whether that is the filter?! that I emptied, it was a screw out ‘cork’ at the bottom left of the washer behind a removable flap!?
Sorry forgot to add that!
July 22, 2005 at 8:20 pm #142930Penguin45
You’re on the right lines – no drain detected within time allowed. The filter is about 2″ in diameter, and unscrews anticlockwise. Hands, knees and torch, check right back into the pump chamber, make sure that the impellor “pings” round freely.
If you can set spin only, check that the pump is turning before replacing filter. If the machine is coupled to a sink spigot (wrong, but people do it), check that as well.
Penguin45.July 22, 2005 at 8:30 pm #142931Ellis
Penguin45 wrote:You’re on the right lines – no drain detected within time allowed. The filter is about 2″ in diameter, and unscrews anticlockwise. Hands, knees and torch, check right back into the pump chamber, make sure that the impellor “pings” round freely.
.Thanks,
I have took the filter out and run a spin and the green spindle is not moving behind the filter housing during the spin, should this be moving?
July 22, 2005 at 8:36 pm #142932Penguin45
Certainly should be – you said green spindle – it has got four blades on it as well? With the power off, you’ve got to search right back into that chamber for any obstructions and check that the impellor will turn – it should “ping” round in 90degree movements when turned manually. If it does turn, but won’t run with power, the pump motor will probably have failed.
An email to spares@ukwhitegoods.co.uk will get things moving for you.
Penguin45.July 22, 2005 at 9:07 pm #142933Ellis
Thankyou very much.
There was a small part of a dog bone jamming the fan, this removed – everything A=OK!
Many thanks again 😀 😀 😀 😀 🙂 🙂 🙂 🙂 🙂
