Hi There
I have an LG WM-1465FHD and the washer has now stopped mid cycle and full of water with an error: OE
I had this error before and the problem was something stopping the blades behind the filter from turning, I have cleared this and there seems to be no blockage.
The only way I can get the washer to keep going is to pull out the black hose and empty all water into that, then the washer spins as normal!!
What can be causing the problem?? ❓
