Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › wm0642hw LG front load with issue
- This topic has 5 replies, 2 voices, and was last updated 13 years, 9 months ago by
djmceltic.
June 25, 2012 at 8:00 pm #70137
djmceltic
ParticipantI have a front load wash machine as described in topic.
The issue is the main connection bolt that connect the motor to the tub keeps coming loose. When it is loose the machine stops spinning and sometimes makes a kind of grinding or knocking sound.
I have tried to tighten it a few times and it lasts about 5-6 loads and loosens up again. I am tightening pretty tight — I have a tendency to overtighten and break things so I haven’t applied extreme pressure yet.
The machine has got a UE error a few times (6 out of 1000 washes) so I am guessing the vibrations caused this. Do I need to order something or what do I need to do to keep this bolt tight???
June 25, 2012 at 9:14 pm #377174QUICK FIX
ParticipantRe: wm0642hw LG front load with issue
try loctite
June 25, 2012 at 9:29 pm #377175djmceltic
Loctite makes sense. Let me ask is this problem normal and could it be a bigger problem? I mean when I tighten it back up it seems that everything works fine… but I am tightening really tight and it still comes undone soon, especially if I do a high spin. Also if I use loctite will I be able to get it off if I need to do a repair?
June 26, 2012 at 3:07 pm #377176QUICK FIX
you should get it back off because they usually come loctited on just dont use too much
July 4, 2012 at 6:18 pm #377177djmceltic
I applied loctite and it didn’t hold.
I took the bolt out and the big metal ring (not sure what it is called). I have never done this before so I am not sure what the grooves should look like on the ring — but they look a little worn.
I applied some threaded tape and loctite to the bolt to see if works better. How do I know if the metal ring with the grooves is not worn out (and what is it called)?
Also I found that LG had a manufacturing issue with my model number with serials starting with an 8 or 9 — of course mine starts with an 8.
July 7, 2012 at 6:24 pm #377178djmceltic
any help?
