WM54p Door seal and retaining band
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts WM54p Door seal and retaining band
  • #89807
    Twoten
    I am looking for a part number for a door sea for a WM54P washing machine, S.No: 93161686.
    The part shown against this model on the connect website shows a seal with a lip about 13mm wide a couple of drain holes.
    I drum front plate has a stainless steel rim next to the inner drum so the door seal has rim of only about 5mm and no drain holes.
    Also, the machine is missing the door seal/front panel retaining rim. This used the type that was held in place by the plastic box that retained the ends of the retaining wire. Having checked into this I believe this wire/clamp is now obsolete so wondered if anyone knows of an alternative the correct size that will work?
    #442612
    Re: WM54p Door seal and retaining band
    Outer clip and wire still available.
    Outer clip C00197553
    Inner clip C00200468
    Wire C00169282
    Seal is listed as the standard 1603006/C00200958. It is a different size but I have managed to fit these to this drum front set up on many occasions. It just pushes the inner lip of the seal forward at bit. Sometimes leave the stainless steel collar off if the gap isn’t to big.
    #442613
    Twoten
    Thanks Jim, that’s great.
    Thanks for the part numbers and advice fitting the door seal. I probably wouldn’t have risked it but will give it a go now.
    Cheers,
    Keith.
