wm63 hotpoint
  • #31432
    hello
    bit of a wierd one
    went out to this wm today spinning instead of distributing normaly tried a motor then a timer no diffrent pulled earth tag off motor and it worked fit a fhp motor re fit earth tag still the same but more intermittent when i take the earth tag off and put the neon tester onto the new motor body its showing live re fit earth and its not checked earth cont plus insulation test perfect reading has anyone come across this before
    thanks
    tony 😕
    #231172
    aqualectric
    Re: wm63 hotpoint
    Sounds like a chafed wire where the loom from the timer to the motor is zip tied to the cabinet. Possibly a tacho wire earthing giving the motor control problem. If it was originally fitted with an FHP motor the loom tends to chafe where the wiring is strapped to the metal motor connector mounting plate.
    HTH,
    Steve.
    #231173
    johnnyj
    Re: wm63 hotpoint
    Is it an old GEC motor? if so check the yellow tacho wires are not chaffing on motor casing, these can cause overheating or spin on wash i always tie them to the brush wire with a cable tie as a matter of course.
    #231174
    Re: wm63 hotpoint
    thanks for the reply
    i replaced the old motor with a fhp plus i cant find any chafed wires wierd one is ive got it on test in the workshop now and it seems ok is it normal for a neon tester to light up on the body of the motor when the earth tag is off and dosent light up when the earth tag is on as its still doing that
    tony
    #231175
    Seamy
    Re: wm63 hotpoint
    Sounds like an earth fault on motor itself.
    Why do you use a phase tester? A test meter is more reliable
    #231176
    maltheviking
    Re: wm63 hotpoint
    Chuck your neon tester away it is only good for a quick check for a live not for electrical safety or earth leakage
    Test the motor with an insulation tester to get a correct reading 😉
    #231177
    Re: wm63 hotpoint
    i am aware of that ive allready checked ins and cont perfect reading i know what your saying about the neon i just thought it was wierd why it should light up when the earth tag isnt connected
    #231178
    wilf
    Re: wm63 hotpoint
    is the motor plug on right once had someone connect wrong and got spin only plus a very hot tacho.
    wilf
    #231179
    Re: wm63 hotpoint
    yes its on ok mate
    #231180
    Re: wm63 hotpoint
    result
    found an internal break on the loom from the timer to the motor about 2 inches back from motor pulled at wire and it broke feeding tacho it was holding on by a few strands which is why it showed continuity from timer to motor you allways get one eh
    thanks for your imput
    regards
    tony
