WM63 timer
  • #23471
    abbots
    hi,
    customer(elderly and nearly deaf), said her hotpoint went bang(didn’t know if it was mechanical or electrical bang), then it finished the program but the door wont open.
    went out to it and opened the door from inside the machine.The machine was dead and the tracks on the side of the timer are burned out(under the first black rast connector).motor tests ok, little bit worried about fitting a new timer to find it blows that as well.
    any common faults to look for?
    is the interlock a prime suspect?
    thanks.
    john
    #198240
    Re: WM63 timer
    New lock, John – that one’s a classic. Timer may repair with soldering iron.
    cornwell40
    Re: WM63 timer
    Interlock can definately take out the timer tracks on these, had that a few times. Have you traced the wires back to the component from the damaged track ends? That is usually a good indication of where ythe fault is 😉
    Tony C
    #198242
    cornwell40
    Re: WM63 timer
    😡 that bl***y Y keeps cropping up everywhere.
    Tony C
    #198243
    roy1
    Replace the interlock,and repair the blown track(s)
    or remove the wire fom the connector block
    and solder it onto the next junction on the
    control unit.
    Roy
    #198244
    Re: WM63 timer
    cornwell40 wrote:😡 that bl***y Y keeps cropping up everywhere.
    Tony C
    Move your chair 0.5cm to the left to cure the problem………. 😆
    abbots
    Re: WM63 timer
    thanks lads.
