any one know why conditioner dosnt go in wma 10 and cloggs
also have a wma 33 that trips main when motor is plugged in checked wire loom and one wire insulation is no good. as soon as motor is in bang changed motor still same door interlock ok pump ok heater ok anyone know????
For second problem: at wma33 if you have rotor to earth schorted (if it is the model with motor on top you can only cut the earth wire from motor connector). Not before checking brush case for earth-leakage.
For first one check all inlet valves or use conditioner diluated.
Re: wma 10 conditionor not going through clogging and wma 33
WMA models are well known for dispencer drawers blocking up, just fit a new ‘un! Or a cheap way is to remove the dispencer & soak overnight in a bleech/water solution ,then rinse in hot water. You could also try a pressure washer on it ,but that is on the extreme side!!
Chris..
