wma
  • #36043
    waters
    The 30mm bearings and seal,can they be bought seperate from connect and if so what part numbers please.
    Also the spider bolts seem expensive so do they do a pattern
    thanks
    #249360
    Re: wma
    Discussed HERE.
    No pattern bolts as far as I’m aware – “other” bolts will fit……..
    Re: wma
    I thought you could buy the seal on it’s own as Connect sell part No. MER026307 “Seal For Drum Shaft 30mm” but what they sent me is not the seal that comes in a 30mm shaft bearing kit.
    I have used Zanussi spider bolts on a WMA spider as there is enough clearance for the hex heads.
