door lock flashing! went for door lock first replaced that no joy checked brushes still life in them but had a new motor changed that too ! track on board looks ok also chip at bottom right of the pcb 😥 last thing to do is replace pcb unless ive missed something any ideas would be gratefull…..also this is doing this on spin when i rotate dial active and door locked light flash on all programs any with this would be apreciated 😳 never had this fault b4 thanks jp guessing pcb
door spring ok ian checked that first thanks m8 have been reading thru forums pcb looks likely will do last known error check tomorow thanks again 😉
