Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › wma 30 will not finish
- This topic has 5 replies, 3 voices, and was last updated 18 years, 4 months ago by
DDSDDS.
November 23, 2007 at 11:01 am #32453
DDSDDS
Participanthi i have a mins then st to me part ex and took it into my workshop where i found broken wires to the motor crimped them and machine seemed to run ok
then i noticed that it had stopped the door lock light wash light rinse light and spin light where all lit up and the door would not unlock
so i changed the board selected rinse and spin program and watched it seems to do one rinse then drains out for about 5 mins then stops with the lights rinse spin and door lock all lit
the door never unlocks and the tub is emptythe motor seems to run ok
so to date i have changed
the module 3 times
the motor 2 times
the motor cable
the pressure switch
the cable to the pressure switch
the cables to the water valves
the water valves all about 3.6
at this time all that is left is the pump heater and valves all are on my list
i have got to the point where i am just changing parts because they are there and i am clueless
also most of the parts came of a scrapper stood next to it with a hole in the drum
(wish i had just swapped the drums b4 i scrapped the other machine and dumped)
help
educate meNovember 23, 2007 at 12:25 pm #235208DDSDDS
ParticipantRe: wma 30 will not finish
sussed
i remember the lady saying she had just had bearings done in the last few weeks b4 buying one from me but that it had not worked properly since she got it back
so i got another wma and checked all the wiring the pressure switch had been wired wrong
it went
wiring block sleeved spade then sleeveless spade
when i fitted new switch i just did one wire on on wire off therefore repeating his mistake put it all back together and wired correctly nows runs a treat
(she bought one from me cos she has not been able to get back in touch with the fellah that did the repair and she could not be bothered with the hassle
hope her bosch makes her happy nowNovember 23, 2007 at 5:51 pm #235209iadom
ModeratorRe: wma 30 will not finish
DDSDDS wrote:
help
educate me, . ‘ ! ? ………. Plus the odd capital letter here and there would be a good place to start. 😉 8) 😀
Jim.November 24, 2007 at 1:49 pm #235210DDSDDS
(L.O:L)
November 24, 2007 at 6:57 pm #235211johnnyj
Have you removed tthe flap valve in the pump, been recalled a couple of times after a tub change for the very same fault as a matter of course now i laways remove flap valve if it has the plastic sump. jj
November 29, 2007 at 9:22 am #235212DDSDDS
Did not remove the flap, as i said the wiring was at fault switched them round to match the machine next to it and away we go.
