Wma 32 will not spin at full speed
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Wma 32 will not spin at full speed
  • #68191
    AASWALES
    Hi this hotpoint wma32 will not spin at full speed it tumbles ok then starts to work up speed and starts pulsing then stops and tumbles again? I had this machine in for bearings and noticed the fault on test after fitting the bearings , customer said it was spinning fine before ?
    Any ideas
    Cheers Alan
    #370146
    jimca007
    Re: Wma 32 will not spin at full speed
    This is quite an early one they were really prone to motor loom problems as it rubbed on the front weight might be an idea to run your fingers over the loom wires individually see if you can find a ” lump ” this is likely to be an internal break. Motor start to ramp up, you get a bit wobble, wire disconnects internally and the cycle repeats…
    #370147
    Allsorts
    Motor loom or Tacho fault .. Had that wit a tacho fault on a few occasions.
    George
    #370148
    AASWALES
    Thanks for the reply’s I will take a look tomorrow
    Alan
