MCB on distibution panel triped and traced problem to a hotpoint wma58s.
strong smell of burning.
on inspection found on main control pcb areas of track damage around selector switch and X1 connector. this connector runs to motor.
the numbers on the pcb are on red sticker
ako 547004-01 hw01
gda 1617205608
mask index 022
70223.01 .04
stamped on board
0440612210
it is a wma 58s
26141813
any ideas where I can get a replacement board?
could the motor have caused this what is the best way to test motor
If the machine is under five years old you are covered by your manufacturers parts warranty. The motor will more than likely have caused the module failure, can also be caused by wiring harness damage.
Hotpoint will charge you just under £90 for labour only, far less than the cost of the parts required.
Looking at that serial number, it is well under five years old.
