wma bearing kits
  • #10552
    streetlighter
    Hi all
    I dont know if its been mentioned before but I have just recieved a wma spider & bearing kit from seme £26.73+ which has a spider, a bearing kit with a new type of seal ( no poxy spring ) and also the fun bit for me 6 spider bolts 😯 .
    hpt 1604770 if any one is interested.
    Unfortunatly I also wasted £10 on 6 bolts at the same time 🙁
    Paul
    #140576
    Re: wma bearing kits
    Its called a ‘Premier Bearing Kit’ 😆
    been available for a while, the seal is a Rubena seal and does seem to be more reliable, time will tell. 😉
    Part number of complete bearing kit is 1604473
    Strangely enough, I fitted a complete drum assy yesterday, that came with the heater in a bag with the two plastic suspension doofers and six spider torx bolts.??
    #140577
    Goatboy
    iadom wrote:…with the two plastic suspension doofers…
    The Hotpoint engineers have a giant, ‘T’ shaped, cork-screw, tool thingy.
    They use that thing to screw into the old doofers, rid ’em out, and just throw them away, and use the new ones.
    Wasteful eh? But I bet it saves alot of time.
    #140578
    Goatboy wrote:The Hotpoint engineers have a giant, ‘T’ shaped, cork-screw, tool thingy.
    Part No: 5600198 (about £25)
    #140579
    Insert smutty inuendo here “……………….. ” 😀
    Personally I grip them tight with my mole grips, depress the small lug then tap them out with a small hammer to start, then pull out with the grips.
    #140580
    Lofthouse
    Spider & Bearings on special offer at the moment £19.20
    Best regards
    Webmaster
    http://www.homespare.com
    #140581
    You can use a 13mm ring spanner on the back end of the suspension pegs to depress the lug.
