WMA bearings
  • #17215
    nigegt
    Has anybody come across a wma with smaller than normal bearings (6205 and 6206) and smaller shaft? I’ve called hotperloni and they dont have a part no and are sure that i’ve made a mistake even when the tech guy rang me back. model is wma54p
    Nige
    #173358
    Re: WMA bearings
    Can you post pictures, I’ve never come across these and Partfinder makes no mention 😕
    #173359
    nigegt
    Re: WMA bearings
    Yeah will do, have got the old parts in the workshop. Sold the guy a new tub back and shaft to save messing around but his cant be the only one?
    Nige
    #173360
    Re: WMA bearings
    It’s strange that they should describe the drum shaft as being 35mm though, as if maybe there were other sizes made perhaps in pre-production?
    #173361
    johnnyj
    Re: WMA bearings
    The service spare is the 35mm as this can be fitted in any machine some lower spin models were fitted with 30mm spiders and bearings.
    #173362
    wilf
    Re: WMA bearings
    yes I had one of those, you can see the imprint of bolt heads in the plastic that held the mould in place . odd looking thing. replaced with standard rear half and spider without any trouble
    wilf ❗
    #173363
    wilf
    Re: WMA bearings
    hold on I cant remember if the pulley was different !!!!!!!!!!!!!
    wilf 😳
    #173364
    johnnyj
    Re: WMA bearings
    It is’nt.
