Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WMA Drum Screws breaking?
- This topic has 7 replies, 4 voices, and was last updated 19 years, 9 months ago by
Martin.
July 12, 2006 at 10:02 am #19103
ParticipantIn April 2005 I called on a customer to clear the sump on her WMA. At the time the drum bearings were shot so I advised her to get the drum replaced by hotpoint as it was only 3′ ish years old.
Got another call today, her machine now leaks and I find that 3 of the two halves drum attaching screws are broken and lying in the sub frame. Clearly the Hotpoint engineer over-tightened the screws when he fitted the rear half tub?
I have never had any dealings with WMA bearings or tubs for that matter. But in order to replace those broken screws, they will need drilling out and a nut and bolt fitting in their place. But, there is too little fixing in the rear tub moulding to do this successfully. So once again it needs a replacement rear half fitting. 🙁
Sadly it now is over 5 years old, and the prohibitive cost of the repair has rendered the machine destined for the scrap-heap. 😥
My questions to you WMA whizz kids is : – How come the screw heads broke? Have they simply been over-tightened or are the screws made out of toffee? Do you replace all the screws when carrying out a repair on a tub? 😕
July 12, 2006 at 10:17 am #181751Goatboy
ParticipantRe: WMA Drum Screws breaking?
Martin wrote:Do you replace all the screws when carrying out a repair on a tub? 😕
Never have done! Never had a problem like that either :con:
I like those WMA tub screws, even though they are torxs. I’ve got loads from scrapped machines, and I use them for all sorts of DIY jobs around the house. I’ve never snapped one!
Maybe it was a Silverback Hotpoint engineer? Or a very powerful power-tool?
July 12, 2006 at 10:20 am #181752Goatboy
Martin wrote:Sadly it now is over 5 years old, and the prohibitive cost of the repair has rendered the machine destined for the scrap-heap. 😥
So, you sold the customer an ISE? 😛
July 12, 2006 at 10:28 am #181753Martin
Goatboy wrote:So, you sold the customer an ISE? 😛
I sold the idea to her yes, and left her with a pretty photo of one and a copy of the tech-spec. 😉
July 12, 2006 at 1:08 pm #181754iadom
ModeratorRe: WMA Drum Screws breaking?
I always say, a good engineer does not need a torque wrench, you just develop a natural feel.
Done loads and never had a problem. (yet) 😉
July 12, 2006 at 1:54 pm #181755Goatboy
Do you tighten all them screws by hand? 😯
July 12, 2006 at 3:10 pm #181756iadom
Goatboy wrote:Do you tighten all them screws by hand? 😯
Yep, always build the drums up at home, have to keep the squash arm exercised, no namby pamby electric drivers for me. 😆
July 12, 2006 at 4:06 pm #181757bzz67
the best way i have found to remove a broken screw `like the ones that snap on modern hoover counter weights`, is to cut a slot in the end of the thread with a drimmel,dont worry if you cut the plastic tub a little.then you can use a flat srewdriver to wind the srew though.
i have never seen snapped screws on a wma but i always use a cordless drill with a torque setting to tighten them.
if you split the tub halves don’t forget to replace the tub seal. -
