Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › wma pressure switch / service test problems
- This topic has 12 replies, 6 voices, and was last updated 20 years, 8 months ago by
bangerman.
August 8, 2005 at 7:24 pm #11186
bangerman
Participantgot a good one here.. sorry if a bit long winded.
WMA 33, door seal change ( due to soap damage, see recent post )
Stripped dispenser draw & cleaned it.
Decided in my undue wisdom that i have a brand new pressure in tool box and i will fit it while the machine is open( had a few problems with this switch in past )new switch is different but part numbers are ok.
wiring is back to front but cannot get wrong as plugs are slotted, doubled checked wiring numbers etc.
machine will not go into service test mode, component test mode works so does switch mode etc.
turn on machine water fills up & up etc,
pressure switch not cutting in.has the main board blown ? if so why. refitted old switch etc
help..
many thanks in advance.August 8, 2005 at 7:33 pm #144266Martin
ParticipantRe: wma pressure switch / service test problems
bangerman wrote:Decided in my undue wisdom that i have a brand new pressure in tool box and i will fit it while the machine is open( had a few problems with this switch in past )
If it ain’t broke why mend it?Why did you try changing the Pressure Switch if the old one was OK 😕
August 8, 2005 at 7:39 pm #144267bangerman
cause i had doubts about it’s levels etc,
and i am a p***k at times…
August 8, 2005 at 7:40 pm #144268litlor
If you manually blow up the pressure switch does it stop filling as Martin says why change it?? You have caused yourself grieve when you are only changing a door Seal!!
August 9, 2005 at 6:01 am #144269bobokines
Pressure switches rarely go out of calibration. They either work or they don’t! If it’s overfilling it is probably due to a blockage.
Surely this is a classic case of “look for an associated fault” If you have just changed the door seal because of mould growth and had to remove and clean the dispenser due to the same, it implies that the sump hose/pressure chamber is blocked too.
Bob
August 9, 2005 at 8:34 am #144270bangerman
water pumps out fast when put into component test mode or onto a spin mode.
When you try to put the machine into service test mode, the relay clicks but no actions.
I think the problem is the electronic side of the pressure switch.
The switch operates with a click if you blow into etc.The main board does not appear to be getting any signals back from the switch. wiring ?
Any ideas.
many thanks
August 9, 2005 at 8:55 am #144271Martin
bangerman wrote:The main board does not appear to be getting any signals back from the switch. wiring ?
Could be 😕
The 2 black leads from the PCB connector go on terminals 12 & 16 on the Pressure switch.Red/Green from the Heater relay on the PCB goes to terminal 11 and the Violet/Green from the Heater goes to terminal 14.
You must also take off and clear the crud from the Pressure Chamber :tup:
August 9, 2005 at 10:11 am #144272bangerman
red/green as stated in manual is actually brown/green on machine.
doubled checked wiring all ok, crud in chamber ok, new drum 2 months ago but checked anyway.
Pressure switch is operating and feed pipe is pressurized, when you take pipe off, you can hear the pressure switch reset.
If you put machine on a cycle , it fills up too much then pre wash light flashes & machine stops, fault code says , machine failed to fill.
and you still cannot get the function test to work, just heater relay clicks.
my assumption is pressure switch is working but front panel does no get the message.
suggest new font panel, are they big bucks etc.
many thanks
August 9, 2005 at 10:34 am #144273iadom
ModeratorRe: wma pressure switch / service test problems
Have you done a continuity test from the pressure switch plug to the module, could be an internal break in the wiring at the plug??
To be honest I do not have problems with the pressure switch on these machines, in fact I have never changed one. I have had this fault many times and it has always been a blockage, not soap gunge but small items that get down the side of the plastic coin trap/filter assy. one was a thin plastic sheet from a credit card, another was one of those “dye gone” sheets. It does not take much to cover the outlet from the sump into the pressure chamber, you need to remove the plastic filter to check.
August 9, 2005 at 6:46 pm #144274bangerman
FIXED…. happy, happy
managed to borrow new board form local hotpoint engineer…
still the same.
i played with the wiring loom that goes from front panel to motor area etc
suddenly lost drum movement but still had spin?
took off motor plugs & refitted, drum now working ok,
after 3 assembles & deassembles problem is cured..
loose wiring somewhere.. but where?
anyway it works… for now
August 9, 2005 at 7:08 pm #144275iadom
If the problem reappears the wiring loom from motor to module is available as a spare, around £3.25 + vat. part No: 1603396
August 9, 2005 at 7:15 pm #144276bangerman
thanks mate, part number noted.
all the besthappy Andy, till next time
August 10, 2005 at 8:43 pm #144277mbdas
I had the same problem after fitting new bearings to one of these turned out to be wires to the control model on wrong never forget that one 😳 -
