Fitted rear half and found no holes for the bushes that push thru to attach the springs that hang it from the cabinet. Holes obviously in front half still but is it strong enough to hold the weight?
Re: WMA rear half with no holes to attach springs?
The 7kg back half doesnt have the holes for susp springs, as they are located on the front half, i made that mistake i put bearings in a 7kg back half and a 6kg back half, i put a 6 kg front half on the 7 kg back by mistake, it wasnt until i went to fit it i realalised what i had done, it could be that you have the wrong one.JJ
