wma stuck on pre wash
  • #29551
    allan
    Hi all, have to go look at a hotpoin wma, customer says prewash light is stuck on, any ideas?
    Regards Allan
    #223583
    Re: wma stuck on pre wash
    Is it flashing or just stuck on? Prewash led flashing can be caused by faulty fill valves ( or taps off) pressure switch or pressure chamber faults.
    You could run the ‘Last Error detected’ routine detailed in the known error codes thread.
    Time out fill – poor supply, valve failure, syphoning.
