I’m a tosser… just done bearing job on it, rebuilt and got no pump-out :-((( Wiring back to board, I’ve got 2 blocks. 1 to p/switch and 1 to pump. with THREE possible locations… x11, x9 and x6… All my manuals stop at wm. Thanks as usual.. Legsthetosser…
hi, the pic in manual is not clear enough to see board markings, but, next to the valve block is the pump, then p/sw next along again, then an empty space & thermistor at end, hth
Pump to X9, Pressure switch to X6 Thermistor to X2.
I do it from memory looking down on the board from right to left, plastic covered amp tag, bare amp tag, square block into back of selector switch, large block to motor & door, then five way block,thenblue/black,.black/black then usually red/red to X2.
Thanks :-))) P.S. I MAY have tried running it with the 2 blocks the wrong way . . could i have caused any damage ????? Reason I’m askin is coz The blocks are now in correct position, and I’ve STILL got no pump action… I’m gonna be GUTTED if I’ve “Blown” it :-((( Cheers Boys.. Legs..
