Hi all , been to hotpoint wma33 would work for about 3 mins then stop, with door light flashing, replaced door switch still same thing, no usual burnt tracks on board, wiring and connectors all fine, if left for a while will work then do same thing. suspect the board and have ordered one from emw as machine in constant use, is this common with board?
Allan
Had one only yesterday, not seen one for a while but it is something I have seen several times in the past, often on the more basic WMA’s for some reason.
Replacement board should sort it but leave the new doorlock on it as well.
