WMA40, constant knocking noise
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WMA40, constant knocking noise
Viewing 15 posts - 1 through 15 (of 17 total)
  • #23457
    Seamy
    Customer complained of a constant sharp knocking noise out of their WMA40 washing machine. When i visited it was as described, when you turned drum by hand once every revolution theres a loud crack. Checked with belt off & still doing it so not motor, i’m thinking its a broken spider leg.
    How much should i quote for this job & what does it entail. Are the bolted on like previous models?
    #198185
    PIP-pm-
    Re: WMA40, constant knocking noise
    Wouldnt like to comment on how much to quote but these are held on by torques screws (the little star shaped thingys that join the tub together) i have never been able to get one to undo yet i usually cut them out of the arm with oxy acetelyne 😯
    #198186
    Seamy wrote:when you turned drum by hand once every revolution theres a loud crack.
    …and I’m thinking it’s a broken spoke on the drum pulley? 😉
    #198187
    MickGeorge
    Had this noise on one of these with a loose pulley but noise stopped when I took belt off.. but might be worth a look?
    #198188
    Never seen a spider fail on one of these and the water round here goes through other spiders for fun. First time for everything but I doubt it will be spider.
    PIP-pm- wrote:Wouldnt like to comment on how much to quote but these are held on by torques screws (the little star shaped thingys that join the tub together) i have never been able to get one to undo yet i usually cut them out of the arm with oxy acetelyne 😯
    You should drill them out, I tried 8mm bullet drills but they used to last for two or three bolts, if you were lucky. Now use standard shape 8mm Bosch titanium drills from B&Q, goes through the bolt heads like butter.
    Seamy
    Cant really see pulley as no access plate on the back of these anymore, just to confirm, when i removed belt you can hear noise but not as bad
    #198191
    wilf
    titanium drills burn out for me. best way to remove spider I have found is to “carefully “cut through the spider arm and bolt as close as possible to the drum with an angle grinder. this will reduce the fixing thread to just a couple of turns which is of little resistance.
    mind you I bet the spider isnt broken there too chunky proberbly a bearing
    wilf
    #198192
    timjam
    I tap the spokes in turn, with a spanner etc. if one is broke it will sound different to the other spokes…..
    #198193
    Has anyone every seen a metal WMA pulley break, it doesn’t have spokes like the 9000/ WM series. I have never seen one fail.
    Alan1476
    I have never seen one of theise spiders break and have done hunreds of them. Either something between drum or a broken bearing.
    Buy the way the easiest way to get the bolts out is in a piller drill. I use a drill bit set from machine mart and co bolt tiped and the 8mm bit will last ages. But that is on the piler drill. If I use it in my cordless drill, appart from being hard work the bits dont last long at all. 😀
    #198195
    DDSDDS
    i have never seen one of these spiders break or the pulleys’s.
    but i have seen many many loose pulleys which cause loud cracking noises when turned by hand this is where i would look for the noise source should just be your flat fee for doing the work i would charge 35 + for it:)
    #198196
    Seamy wrote: when i removed belt you can hear noise but not as bad
    Time to “bearings change” or inner tub spider is broken.
    Open the door: one hand on the back side = keep steady the puley
    and other one on front try to move drum up and down (without rotation) :bounce:
    You should fill on the back movements of drum (bearings to change); if not then spider is broken.
    Baron 8)
    With belt OFF…
    And also plug.. OFF…
    #198197
    If the spider is broken on this then it is the first instance I have ever heard of. I did have one WMA based washer dryer that had a 20p coin wedged between the drum spider and the stainless steel inner drum at the very edge of the drum, catching as it revolved.
    I won’t go as far as to say I would show my posterior on the town hall steps, but I will donate £50.00 to a charity of the OP’s choosing if the spider is snapped.
    Jim, accepted… is good also one digital beer :beer: :beer: :beer:
    Inside drum I had (if I remember good) four times unlocked axel( bearings axel has made a little movements inside spider ) X— :bounce:
    … so is like one broken spider. 😈
    (excuse for not knowing to do my self more clear because of my English)
    Baron 8)
