Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WMA50P
- This topic has 10 replies, 3 voices, and was last updated 13 years ago by
Profyaffle.
April 6, 2013 at 1:56 pm #74908
Profyaffle
ParticipantAfter Tech info please peeps. I’m in need of the board connections. Thanks
April 6, 2013 at 2:14 pm #393205April 6, 2013 at 2:37 pm #393206Profyaffle
ParticipantRe: WMA50P
Yes mate, Hotpoint WMA50P if you can please.
April 6, 2013 at 2:40 pm #393207Profyaffle
Yes Jim, Hotpoint WMA50P
April 6, 2013 at 3:04 pm #393208iadom
ModeratorRe: WMA50P
Yes Proff,it’s a WMA, all the same apart from the digi display models.. 😛
April 6, 2013 at 4:52 pm #393209Profyaffle
If you could Jim, I’ve had Ultima Vogue 2 Digital diagnostics but nothing relating to the rotary control board.
April 6, 2013 at 4:55 pm #393210madangler1
What’s the problem ???
April 6, 2013 at 6:20 pm #393211iadom
ModeratorRe: WMA50P
madangler1 wrote:What’s the problem ???
That’s what I was wondering, all the connections are the same for the rotary controlled WMA models and you only asked for connections, not diagnostics???
April 7, 2013 at 8:01 am #393212Profyaffle
I’m thinking I’ve put a connection on wrong to the user board as it’s filling and going through the program ok until rinses. I’ve checked everything else, heater etc and it was pumping when I first put it on to confirm the fault that the customer reported. Scoring on all the tracks confused the reassembly once the board was repaired. Simple job but there is more than one place that two of the connections can go. I don’t want to blow the board so relevant info would be a great help. The Ultima info is diagnostics and not relevant.
April 7, 2013 at 10:10 am #393213iadom
ModeratorRe: WMA50P
This info from that thread I linked to gives the numbers of all the positions of the connector blocks and their ultimate destinations, they are exactly the same on all rotary control WMA’s
‘Looking down on the back of the board from the top, working from right to left, its one plastic sheathed amp tag and one unsheathed amp tag, one white, square plug into selector switch, large conn block from motor/doorlock to X1, 6 pin block, valves to X5, blue/black, pump conn to X11, black/black, pressure switch to X9, red/red, ntc to X2 and if fitted the small conn to the facia variable controls to X4’April 7, 2013 at 11:43 am #393214Profyaffle
You are a star, sorry I never twigged it was a link, obvious now though! Thanks again for your always prompt responses
