WMA60P Throwing belt off
  • #26675
    Went to a WMA60P today which keeps throwing the belt
    off for no apparent reason. I have fitted new belts on 2 other occasions
    but usually have to go back every 6 months or so to refit…
    whilst I dont mind its a nice little earner I was wondering if there is
    something im missing…..bearings seem fine and no movement in
    drum I can tell….only difference is that it has a plastic pulley?
    Any ideas Cheers Col
    #211007
    indespoint
    Re: WMA60P Throwing belt off
    If belt and bearings are ok id go for the pulley itself
    #211008
    Sorry didnt mention but pulley seems fine as far as I
    can tell…..no access to it from the back but
    if I tap it with a screwdriver it rings ok…if that makes
    sense as its not metal!!! but no thud sound as if
    cracked or something!!!!!
    #211009
    recall
    If pulley had gone it would throw it after 2 loads and sound horendous (i think that how you spell it? 🙂 ) on spin. Last ones ive seen you would feel by hand easily
    #211010
    recall wrote:and sound horendous (i think that how you spell it? 🙂 )
    Not quite 😉 If you use Internet Explorer 7 then why not download this little utility. http://www.iespell.com/
    You can use it for all on line postings. It now works via the right click menu, type your post, highlight everything, right click, select ‘Check Spelling’ . Make sure you alter the default language settings from English US to English UK.
    PS. ‘horrendous’ was the only one it spotted in this post. 8)
    #211011
    recall
    cheers for that one. il have a go.
    #211012
    mvitorio
    I had one once that had cracked the front single motor mount bracket on the tub. All appeared ok until it had a load in which caused motor to flap and throw belt off.
