Re: wmb61631s drum not turning.
Tacho generates voltage but only small amount as kwatt says lv. as magnet spins north /south pcb then measures the voltage to determine the speed but it does not produce much current so i can’t see it blowing the track. I would look towards the motor coil and drop your insulation tester across it on its highest setting see what you get, if nothing shows try it and spin the drum by hand as your testing it to see if it throws up anything might be you have a weak spot on your motor
