Hi I have a problem on a
Beko: WMB91442LR
s/n :13-400392-06
Prod :7110841600
It will not let you select a program, just flashed 34 mins left then end, you cannot reset it. I have fitted a new board and it does the same, no earth leak on heater or motor and have taken these out of the circuit by disconnecting them it still does the same.I have also disconnected the program selector but the issue is still there. If you try to start the program it will fill for a few seconds the drain for a few continually. Customer reported seeing it saying it had a F13 fault but i cannot get it to do this.
Also if anyone has a service manual for this it would be muchley appreciated.
Jazz
