wmd940 f02
  • #68215
    dopper
    got this h/p wmd940 gets a f02 code half way though wash, motor seems ok heater ok , what else can it be, the pcb ?
    dop
    #370206
    Re: wmd940 f02
    F02 = Motor jammed/Tacho detached/Check connections between motor & module.
    #370207
    Johnnyboy
    Re: wmd940 f02
    Just been to one today except it did the wash all the way through, she says after 20 mins it comes up with f2 but after 50 mins of waiting I bailed out only to be called again to be told it had done it again. Dodgy harness to motor ???
    #370208
    dopper
    Re: wmd940 f02
    will check the wiring harness
    #370209
    jimca007
    Re: wmd940 f02
    Had this as a ” Ghost ” fault when the capacitors are going down on the main pcb whip it out and give them a visual for leakage or bulging on top.
    #370210
    dopper
    Re: wmd940 f02
    will take a look at that cheers
