WME7247S beko motor fault
Home Forums Public Support Forums Help And Support Washing Machine Help Forum WME7247S beko motor fault
  • #88584
    petehall347
    i will start at the beginning ..
    i was given this machine with error code e11 coming up and no motor action .
    i plugged it in and it seemed to be working ok . ran it through the test modes and it passed the tests .
    installed the machine and tried a full wash cycle all went well until final spin which it didn’t complete . tried test modes again and i hear the various relays clicking .
    removed motor and bench tested continuity which seemed ok so wired it up to bench test and motor spins no problem .
    i removed the control board and replaced T1 the triac on the heatsink . tried board back in and still no joy .
    i am thinking the AC power is not getting to the control board so will do some continuity tests next .
    i could really do with a schematic for the board and wiring diagram for the machine if anyone has these please ?
    thanks in advance for any pointers .
    #438649
    petehall347
    Re: WME7247S beko motor fault
    well that turned out to be relatively easy .. found a corroded off wire at the motor multi plug . soldered and crimped terminal back on ..was the violet wire ..
    its got a load in it for testing ..
    hope this helps someone else with the same intermittent problem
    #438650
    petehall347
    well it has just blown the door triac on the front board and 2 resistors . i have triacs but no resistors .they are on order . i suspect the switch blew the triac so i already replaced the switch .
    #438651
    1totalshambles
    I admire your determination. Thanks for the up date after the 1st time you fixed your machine back in June last year. Let us know the outcome of this lastest disaster.
    #438652
    petehall347
    good news .
    resistors came in today and a brand new 1mm iron tip that makes it much easier than using the 2.3mm tip being as the resistors are 0805 smd devices .
    anyway just done a full on wash approx 2.5 hrs at 80 degrees .
    finished program no problem . nice clean laundry .
    seems to have spun better this time .may have been the trolley token at fault i found in the pump filter ..
    #438653
    petehall347
    have not used the machine for a while now . put washing in earlier then found it had e09 fault .suspected door triac yet again . stripped the board out and sure enough the triac was blown apart . fitted new triac and its now working again .
    there must be a strange fault with this machine to be blowing triacs when not in use .
    #438654
    petehall347
    bloody thing has broken again .. different fault though . fills with water ok but drain pump is running continuous . fault is e08 . water not filling up .well it cant fill up with pump running .
    must be a problem on the pcb . maybe pump triac is switching on when it should be off ? i dunno . i know the triacs arent testing shorted so i will have to dig deeper .
    #438655
    fault can also be pump triac short circuit
    petehall347
    problem solved .
    traced and changed drain pump triac .. its now washing normally .. hope it stays that way for a while . this thing seems to like eating triacs for some reason .
    #438657
    petehall347
    it smoked today but nothing obvious on the pcb.s . no shorted triacs . nothing looks burned but it smells of burning .maybe from previous burning triacs
    fills with water as soon as door is closed .
    fault code e10 comes up so might be door switch faulty .
